For sale is my 1999 JDM Nissan Silvia S15 Spec R.
It has the full original factory aero kit, which are quite rare.
The car is stock except for a blow off valve, pod filter, and 18 inch G2 Wheels.
I have the compliance papers when it was imported back in 2007 by TGS Performance.
Good car, nothing mechanical wrong, body and interior in pretty good condition.
It is an auto (rare for JDM S15), but manual conversions are cheap and easy enough to do.
Only 115,000kms, always garaged.
Comes with stock s15 rims with decent tread on them.
After about $18,000.
I am also considering trades, with cash adjustment either way.
Located in Clayton, near Monash University.
Feel free to text or call me on 0422 239 525.
  • 1 month later...
  • 2 months later...
Price drop to $12,000, but no registration or RWC. Or $13,500 and I get both. Prices are firm.
For a RWC, some mechanics might knock back the tint, and the rims. Apparently you can only legally go one inch up; the tread is fine though.
Contact me using my carsales number.
Considering trades/swaps again. Japanese only and ideally an upgrade with cash your way.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
