Seems like people in here wanna make 20psi @ 3000rpm and make 350kw at wheels LOL
We can... ditch the RB's and whack a LS2-tt :) haha
Just keep it civilised yeh. We are talking stock comp engines as well, which makes those amazing results kind of redundant.
There are many people making well over 330kw @ 20psi on a "stock comp" motor having seen them my self and a load of them in the "RB26 Dyno Reults Thread". Few boltons and a good tune goes a very long way ;)
Edited by nomnomv8
Hey i got a r32 gtr making 287 at around 14 psi and making 320 at 17.5 psi. and its got more in it. i need a direct feed of power to my fuel pump and my intercooler is running at its max capacity and please noone go on about the coolers coz if spoken to high degree engineers and they both have told me the max airflow factory intercoolers produce.
so in saying that my car is making 320 at 17.5 psi leaning out. if use say that the gt-ss dont flow much use are wrong they are great turbos response wise and power wise. if use want big power go single or -5s but then u wont have as much response. its a catch 22.
i can post my dino sheet up if use want. its got tuned by JEZ.
Dont let Nismoid hear you with that slander on OEM GTR intercoolers !!!! Tell your engineers that they are wrong :whistling: Edited by nomnomv8
Yeh I read they're pretty good. All I know is that after a good flogging in the hills she'll still be nice and cool to touch on the outlet half of the cooler and warm on the inlet side, so it should be working just fine ;)
Using stock cooler aswell?
yeh thats stock cooler but as u can see the graph hasnt flattened out so hopefully by getting a good intercooler (im saving for hks) and rewire fuel pump and abit more boost i should get better number. im happy as is, JEZ did a good job tuning the car runs all day everyday without any problems and in the end thats what u want.
maybe your engine is running out of puff. .
Whos is?
I dare say you will be wasting your money on a bigger cooler at that power level.. If anything you will loose response for bare minimal gains up top
Edited by GTR_JOEY
Yep sure am mate. I think even after a full 20mins on the track during sprints the thing was still cool at the driver side end and that was during the warmer months too
Does that mean Im not your favorite anymore? :(
Haha ;)
You wouldn't have any other videos floating around in addition to the one you have on your build thread? It would be good to see yours in action.
Here's mine at Willowbank with the N1 turbos....she'd definitely go nicer with the -9's
Excuse the pansy launches and the HD video quality :D
Edited by tommis85
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
