I've got all this gear that won't be put to use on my new build, so it's gotta go!
1. GT3076R turbo kit
Includes
- Garret GT3076R near new less than 1000k
- Tial 38mm external wastegate near new less than 1000k
- custom made screamer pipe used for 50kms MAX
- custom made 3 inch dump pipe, wrapped in billion exhaust wrap used for 50kms MAX
- custom aeroflow turbo and waterlines used for 50kms MAX
- Hybrid performance steam pipe manifold used for 50kms MAX
-GT3076 custom oil drain piping
All is near brand new, and is essentially everything you need to have a great setup. This made 318kw on 15psi on my RB25.
not looking to seperate.
$3000
2. Power Enterprise 850cc sidefeed injectors
Near new, used on my car for 50kms max. E85 compatible.
includes a Nismo FPR, fuel rail and modified OEM injector harness.
$950
3. OEM RB25 side feed injectors in fuel rail
No use for it
$120
4. RB25 cam covers and front timing cover
no use for it
$120
5. Nismo twin plate push type clutch
made by Tilton
plenty of meat, great pedal feel. Held over 300kw without problems.
$800
6. Trust DD exhaust
back part modified so it's one piece.
includes 3 inch de-cat pipe.
$400
7, Cusco catch can
no use for it
$120
I am happy to ship at buyers expence. I am open to offers but please don't waste my time lowballing.
I am located in liverpool region, NSW.
PM me if you are interested.
Thanks,
Adam.
Generic rear arm kit:
Includes:
Rear camber arms
rear traction arms
rear toe arms
will fit R33 R34 S14 S15 C34 and maybe some others.
barely used, great condition. Bearings are like new.
$300 shipped
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=391834
9. 3 inch blast pipes
Brand new, no use for them.
$180 shipped
10. 3 Inch resonator
brand new, no use for it. Same as in picture but painted silver.
$80 shipped
Includes:
Rear camber arms
rear traction arms
rear toe arms
$300 shipped
Does this eliminate hicas?
Shit, I forgot about that.
Nah I've got an S14 subframe in my R33 :(
So these will fit S14/S15 and C34 fine. R Chassis will need to ditch the toe arms (where HICAS sits).
14. KTS inner and outer tie rods
Changing my setup, adds lock and reduces bumpsteer on slammed cars.
Fits 33/34/S14/S15 etc
$220 shipped
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
