Hello, here are a few spare parts I had on my R33 but am trying to get rid of. I'm located in Melbourne's east. I'd prefer local buyers only.
HKS mushroom pod filter with bracket and R33 GTS-T adapter $50
Turbosmart Kompact plumb back blow off valve in black, perfect working order $100
R33 air refiner (Puretron), doesn't have any of the wires unfortunately $10
Slip on wheel spacers, 3mm, 5mm & 8mm, all for $30
Thanks for looking!
https://www.sau.com.au/forums/topic/403820-r33-aftermarket-parts-and-spacers/
Hey mate, sorry I didn't see you said that. Should have inboxed me! I still have it and I can help you change it over too if you still want it.
Pod filter has been sold, still have the rest.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
