Hey guys,
I'm really interested in getting some skirts for my currently stock R34 25GT Coupe. The side skirts and rear bumper are pretty much taken care of but i am having some trouble with the front bumper. If possible, i would really like a Z Tune front bumper or a Top Secret front bumper.
The pictures attached are of a Top Secret front bumper. This would be perfect. Anyone know where to get one?
Also, i know of one place where they install parts like this but does anyone else know of a reliable place to get skirts and bumpers fitted. I am in Melbourne, VIC.
Any helpful suggestions would be much appreciated.
Thanx
Edited by NISMO.SKYLINE
https://www.sau.com.au/forums/topic/403877-r34-front-bumper/
Hey mate, post a thread up in the want to buy section. I'm sure someone will have one lying around. you can install the front bar yourself, its very simple and straight forward. I got the same car as yours and it took me 15 mins to take it off
As for the Z-Tune front bumper, JSAI here in Sydney makes them for the R34 GT/GTT.
From what I heard, the quality of his work is pretty good. His service on the other hand... lol
Z-tune front bar: http://jsai.com.au/i...emart&Itemid=29
Pretty sure he has distributors down in Melbourne too, but having trouble remembering the names. Maybe someone can help out
Appreciate your help Jack but trust me, i have seen that one on ebay and its not exactly the one i want.
From a head on view, the one on ebay has got one hole on the left side but two holes on the right side (one for the indicator of course but the other one, i'm not sure). I'm specifically looking for a Top Secret front bumper like the one in the pics that i initially posted where it simply has one hole on each side for the indicators. I know, its quite picky but that's what i'm looking for.
Thanx for your help anyway Jack,
Phil
Just an FYI,
Phil, the one you are after is the gtt top secret front bar for a gtt,
The one Jack posted is the gtr top secret front bar 'to suit a gtt'
I like them both but prefer the one jack posted only when it has the additional lower lip :)
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
