  • Replies 180
Posted Images
Brisbane/Gold Coast V35 Owners Cruise:
Date: Aug 18th 2012
Cruise Details: Brisbane to Point Danger Light House, Tweed Heads
Route Length : 104km
Meeting Place 1: Mc Donalds @ Springwood at 9.30am for a 10.00am start
Meeting Place 2: BP @ Yatala at 10.15am for a 10.45am start
Final Stop: Point Danger Light House ( anticipated reach time at 11.30am) Lunch and then return to Brissie or as per crew suggested plans
Confirmed List:
1. Tony350 (+Victor)
2. 4evershiva
3. FlyingEL
4. Sheldon
5. Vthirty5
6.Kolossus +1
7. Spencer
8.n15m0
9.Bradstreet
Hopefully we get a 100% attendance of the above people....hope it doesnt turn out like the last one....Sheldon,Joshua and victor knows what I am talking about....So please guys lets make this cruise a good run....
  • Brisbane/Gold Coast V35 Owners Cruise:
    Date: Aug 18th 2012
    Confirmed List:
    2. 4evershiva
    3. FlyingEL
    4. Sheldon
    5. Vthirty5
    6.Kolossus +1
    7. Spencer
    8.n15m0
    9.Bradstreet
    10.Lineit up
hey sheldon, as you are the local guy of GC, would you be able to lead the cruise and take us through a quick lap into gold coast city to get some view and a show of our V35's to be spotted and then head to danger point.....
Edited by shiva
Date: Aug 18th 2012
Confirmed List:
2. 4evershiva
3. FlyingEL
4. Sheldon
5. Vthirty5
6.Kolossus +1
7. Spencer
8.n15m0
9.Bradstreet
10.Lineit up
I'm out gents. Car won't be ready. :(
If someone wants to pick me up, I'm happy to tag along but yeah, V is still off the road.
What? Now I lost a ride. Lol. Hope to see you next time, mate.
Anyone want to have a passenger? :)
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
