Hi all, just clearing out parts scattered in my garage.
1. R33-R34 (2WD & 4WD/S14/S15/C34C35 Silvia/Skyline/Laurel & Stagea (2WD & 4WD) Garage Miniz Camber Arms - less then 50km usage on them, not your typical chinese crap $140
2.S14/S15/R32/R33/R34/C33/C34/C35/Z32/A31/Y32/Y35 Silvia/Skyline/Ceffie/Laurel/Cima/Gloria/Stagea Garage Miniz Toe Arms (non hicas only) - less then 50km usage on them not your typical chinese crap $140
Paid $220 each for these awhile back.
http://www.garageminiz.com/parts.html
3. R34 GTR OEM Black Alloy fenders with OEM indicators - Paint is in excellent condition, stored in bubble wrap, never got around to fitting the, came off Chuey's sexy Z tune styled R34 GTR $450
4. R34 GTR Carbon Wing blade, needs custom alloy end plates in 2mm thickness to fit, alternatively you can shave the blade down 2mm on each side and use the OEM end plates, or run it without the end plates with a 2mm gap on each end but there will be no adjusitibility, brand new and no damage, in excellent condition
purchased from DOR134's group buy and no longer needed $90 FIRM
5. Defi style 60mm black face gauges - Boost/Oil Temp/Oil Pressure; only boost gauge has been used for a week then removed, others are brand new and all gauges still have protective plastic on front of gauge. some scratches on casing, exact functions real defi's for a fraction of the price $130 for all 3, otherwise $50 ea comes with a free sandwhich plate for oil sensor fittings! Suit RB's.
5a. MearCat.com.au dual gauge pod suit 52mm gauges, made from strong fibreglass$50 FIRM
RRP $99 + delivery & $5 per hole drilling
http://mearcat.com.au/
6. HKS/Earls oil cooler suit R34 GTT/R33 GTST w/ Thermostat - non relocation type
HKS thermostat/block fitting, Earls customer braided lines and core
fins are in good condition, no damage to core or lines/fittings, $250
7. Zeal Function Front coilovers suit R32/R33/R34 $70
springs alone cost more than this, they are well used, eye mount bushing is in good nick still, however shocks are near dead and will suit as a temp solution or to keep a car rolling
8. R33 GTST 5x1 rear half shafts > diff to Hub
looks like these but with a bit more surface rust $50
9. R32 GTR non brembo brake rotors, still some meat left and lots of surface rust due to being outside $20
10. Blitz DD Venturi BOV, comes with universal flange with hose fitting; held 18PSI fine, no front piece attachment $50
11. R33 GTS/GTST/GTR Carbon A pillar covers - stick on by 3m or sikaflex - your choice, has a minor chip in one, $40 FIRM
12. R34 GT/GTT/GTR carbon windshield/wind deflectors/rain deflectors - fit by 3m double sided tape and sikaflex for extra strength. has a small hairline crack in it, purchased from DOR134's group buy but no longer needed $50 FIRM
fitment pictures here:
http://www.skylinesa...ost__p__6292930
13. AVS Model 7 18x8.5 +38 (if i recall) pair of rims with thrashed tyres, sprayed black but no damage to rims and in good condition;
$150
looks like these;
Items are located in Sydney near Gladesville or Orange Grove, prices are ONO unless FIRM is stated and excludes postage!
Interstate buyers to pay for all postage costs.
this is all i can find atm, i will add more in the coming days as i uncover some stuff!
Thanks for looking,
Keen on oil cooler, just a few questions
What filter do you use for it because I know they are pretty tight to get in and out as it is?
Come with mounting brackets for the cooler?
Core size measurements so I can have a good look to mount it?
Freight to Adelaide?
Thanks
Edited by rb2534
Hey rb2534,
i have not actually fitted this to my car, however finding an oil filter to fit should not be too hard to find and i would assume it would fit OEM filter,
Height: 14cm
Length: 29cm
Dash 10 hose fittings;
approximately $20 to Adelaide,5000
Cheers!
EDIT: the AVS rims are 17x9 my bad! $100
got these 2x ford xr6 falcon wheels for skids/spares 17x8
$50
blitz bov
Interested in carbon blade and weathershields for the r34 gtr. Can you please email me pics [email protected]?
Thanks Adam.
Thanks Adam.
I'll send pics over shortly, cheers
Hi, Will take the R34 GTR fenders have sent you PM
Someone else has already contacted me and has first dibs, if sale falls through I will let you know ASAP. Cheers
R34 windshields, ZEAL coilovers and R34 GTR fenders all PENDING PAYMENT
reasonable offers welcome guys, worst i can say is No/
  • 4 weeks later...
EVERYTHING SOLD EXCEPT
blitz BOV
R33 GTST 5x1 rear half shafts > diff to Hub.
bump, these stuff need to go
**********$40**********
**********$50**********
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
