It's time to start looking for some work placement for the end of the year and I really want to get a job that is related to the automovotive industry. Specifically I am not really fussed. I live in Brisbane and am In my 3rd year of studies at the moment but I don't mind looking for a job anywhere in Australia or even internationally.
Any sugggestions? I was not sure where to post this so I figured this section would do.
http://bradken.com/careers/graduate-opportunities/graduate-cadet-online-application
Try my company - we don't do vocation work as such (it's just not called vocation work..) and it's not automotive (though, some of our plants do manufacture automotive components) - depending on what sites you put down you could be involved in component design, process improvement, project management, quaility control or manufacturing etc which will all relate back to the car industry.
There looking for people to put cadeships for final year too, so it may lead into a permanent job (i'm meant to be working with a team of ~10 engineers, of which their are currently 3-4 vacanciess...this is just my sub-division alone...so no shortage of jobs)
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
