Hi guys i am chasing a front bumper as i have a nice hole in my current one. Can someone please help me out with any advice as to what are the chances of getting one in perth without paying a arm and leg for one. Also if anyone has got one for sale please PM me or email me on [email protected] .
I need to get this fixed as soon as i can.
Thanks a lot everyone.
https://www.sau.com.au/forums/topic/404268-wtb-v35-2003-2door-front-bumper/
This is the bumper i'm purchasing very shortly - http://www.ebay.com/...ssories&vxp=mtr
AND i'm getting this grill insert with it, mix these together and it looks mint! personal opinion though.
http://www.ebay.com/...54558c7&vxp=mtr
Edited by Seano350GT
well shipping from america is usually very expensive, for the bumper im guessing it will be an extra ~$200. The grill insert should be about $80 shipping.
Yeah i will be selling my stock bumper, it's got paint chips and a bit of scrapes but i can get it cleaned up and sell it to you cheap as hell, nothing wrong with it apart from that.
Let me know.
Alright mate, i'm keen to get myself the Nismo bumper. Mainly because of the style, and the previous owner of my V has managed to scrape both corners. I'm super careful with my car but the driveways in Mackay are all steep! I will PM you when i get the Nismo bar, will most likely be 3 weeks or so and i'll get this cleaned up once the new ones on. Just noticed your in perth too, i'll get freight prices once i get the new bumper :)
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
