Weds shocki 18x11-10 and 18x9.5 +5 (1 of the front has small buckle on inner) $2000firm an extra $180 to fix buckle
fabouls expands 18x11-13 with new 235/45 rotallas $1500
work (not sure on name but drift squid has a set so there good) 18x11-13 with new 235/45 rotallas $1500
Nitto Built R34 NUR RB26
This was a brand new n1 engine that I just built lucky if the engine has done 1500ks since new and now the new nitto rebuild has just been run in.
N1 block, head, crank
Nitto JE forged pistons
Nitto I beams
Nitto mls head gasket
Nitto oil pump
ACL race bearings
ARP studs
Supertech stage 3 valve springs
kelford 272/272 cams
OS giken cam gears
genuine nissan timing belt
Ross tuff bond harmonic balancer
extra oil drain in back of the head
modified rear sump conversion with tomei baffel kit
dash fittings on rocker covers, oil drain, heater lines
tomei oil cap
NUR coil pack cover
Motor was built by mrc dyno and nitto recomended duncon foster to do machine work..
This motor will be awesome for a gtr that wants to push good numbers through it and start with a new motor, not one that had 100ks then rebuilt.
any info ring me. Have all recipts
$15000 pretty soild on price, this is half price of what it cost.
GTX3076 with .82 divided rear housing
6boost ceremic coated manifold (this was made to suit a 33 gtr turbo high mount position but fits all s13/14/15 rb conversions)
2x tial 38mm mvs
2x ceremic coated screamers made by Hypertune
3.5inch stainless v band dump pipe in heat wrap, made by Hypertune
Front cooler pipe with 2 dash 4 nipples made by Hypertune
Teflon braid oil feed through filter
Teflon braid water lines
Teflon braid return line
Braided vacum lines to waste gate
Nitto multi layer gaskets to suit rb26
4inch inducer pipe made by hypertune
Drift pod filter
This kit will suit RB20/25/26 6boost manifold flange
This turbo set up has only done 2track days and dyno day
This cost me: GTX3076 $2000
6boost twin scroll manifold $1200
2x 38mm mvs gates $640
ceremic coating $550
Teflon Braided line and fittings shealding etc $700
work to fit turbo and coolerpipe, dump,screamers,inducer $2000
Around $7000 in total, IM askin $4500 firm for all of this and its all new.
Turbosmart vee port blow off with alloy cooler pipe $250
Polished RB26 intake plenum with ITB's, Linkages,The sectiont that bolts to the head, vacum chamber, water neck
Im askin $700
Exedy twin plate clutch to suit rb, plenty of meat only done a couple of drift days.
Im askin $1100
Expurt 1000cc injectors, plugs to suit, rail and fittings
Im askin $700
brand new rb starter $100
Reco rb alternator $100
Canton Accu sump with teflon lines, electric solinoid and pressure switch, t piece to t into oil cooler, mounting brackets, custom made cover made by hypertune.
This is the biggest accu sump canton sell, holds 2liters of oil and couse of the size its hard to mount in engine bay, i had it mounted on my cage, thats why i had the cover built to pass scruteniring. This owes me around $1300 but askin $850
S14 s2 tube front end shell (reapers one) non rolling bare shell, has rhr damge, rails are straight, damage can be pulled out. $500 firm
BN type 4 s14 s2 brand new in plastic front gaurds $750
BN type 4 s14 s2 used and damged front gaurds, both gaurds have crakes but all pieces are there and easy fixed with fiber glass $200
Nismo copy s14 s2 bonnet damaged front right is cracked needs fiberglass repair $50
S14 CUSCO half cage $550
s14 dash with custom switch panel $400
S14 s2 boot lid with 4 holes $50
a14 1 left hand side genuine CHARGE SPEED rear wide body gaurd $100
s14 1 left hand D-MAX copy rear wide body gaurd $50
S15 white bonnet $250
S15 left gaurd with a small ding in it $50
s15 right gaurd $100
cannon to suit s15 $150
s15 stock front bar $100
s15 stock radiator $80
s15 a/c condensor $50
This is all i can think of but theres more crap ill put up next week. located in castle hill ring pete Contact Seller
photos http://imageshack.us...0706181631.jpg/
Ill get the alternater of u pete
Sad to see this go. I can vouce for this being a 100% no expense spared genuine build/ sale.
Edited by ydr030
that is one crazy setup, bit off topic but how much power were you making and on what boost?
was makin 375rwkw on 20psi and 392rwkw on 25psi and turbo started to run out and on e85..made 330rwkw on 18psi pump fuel on run in
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
