Up for sale is a set of front AP racing 6 pot calipers (AP7040), comes with a set of ap dog bone to suit S13,14,15 and R32 skyline. Will also suit R33,34 as well by rebored and re-tap the 2 holes to 14mm
Great condition as pic, minimal usage. Also comes with a set of BRAND NEW set of disc hat and high tensile bolts.
So all up:
2x Ap racing 6 pots calipers ------------------------------------- Used, Great condition
2x goodridge hose and fittings bolt straight onto any nissan--------Used, Great condition
2x 5x114.3 alloy center hat to suit AP rotors----------------------Brand New, Freshly machined
2x dog bone to suit S13,14,15 and R32 Skyline--------------------Brand New, Freshly Machined
24x High tensile Bolts to join the alloy hats and rotors--------------Brand New, Never used.
4x high tensile bolts for calipers and dog bone---------------------Brand New, Never used
So all you need is a set of AP rotors and off you go!
Reason for selling, A time waster put in a deposit and asked me to ordered it then changed his mind. BAD!!
Pick up or posted. Price is firmed considering a brand new set will cost 4.5k.
Happy to order a set of Genuine AP rotor as well for $900 with 4 weeks lead time. Payment to be upfront and no 'change of mind'
will freight at buyer's cost
Call or text 0433289998
Cheers
joe
Just for info, the R32 and R33 brembo use the same hole size 12mm, only the R34 uses 14.1mm.
Also not sure where you get the Ap7040 kit for $4.5k. Sellers on the forum offer these kits brand new for well under $4k. Maybe you are thinking the CP5555 kit?
  • 8 months later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
