Ok guys that time of year again. Im relatively new to this forum so was just wondering who is going and wat type of cars are entering. Sorry if this has already been posted elsewhere.
Thinking ppl could throw a couple of pics up of there car and some power figures to go with it. I wanna see some good hp cars there this year hopefully jot as much stock skylines and commodores.
Quick list of work is fully built 26/30, 6boost manifold, haltech, hks t51r, nitrous. Made 648@who on 22psi. Going back on dyno next week with more boost so fingers crossed that number will start with a 8
Edited by NUT515
https://www.sau.com.au/forums/topic/405219-powercruise/
To be totally honest I've nve never drivem n it yet lol. Im over in wa and it only got fired and went on the dyno last Tuesday. Still got 9 days til im home to drive it lol. Full power by 4800 so it is a bit laggy. That's was the now is for tho just to get her spooling not for top end. Hopefully drop by 1000rpm once I turn the bottle on
https://www.sau.com.au/forums/topic/405219-powercruise/#findComment-6452703
I'll be going in my R34 gtr vspec on track. Its such a good price for 4 days of fun! The car Is on a run in tune at the moment as the engine just got rebuilt.. Its at18psi and is making 390Hp at the wheels. Although will be taking back to gt auto to see what we can bump it up to in the next week or two.
https://www.sau.com.au/forums/topic/405219-powercruise/#findComment-6464723
  • 4 weeks later...
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
