Rb25/30 Long Engine, T67-25G Kando & Tial W/g, Freddy Intake & 80Mm, Power Fc & Nismo750Cc
Will only seperate parts once engine is sold!
RB25/30 Long motor rebuilt november 2011,
Reco head with welded vtc and waterjacket, RB20 inlet cam, 25 exhaust cam, metal head gasket.
Linished std crank, crank collar, N1 oil pump, New acl bearings and moly rings on std RB30E pistons & rods.
1.2mm restrictors, block drilled, lightly honed. New Exedy HHHD clutch, timing belt, idlers and waterpump.
Can see running and fitted to vehicle.
$1650
Kando T67-25G with Tial MVR 44mm wastegate mounted off exhaust housing.
Includes modified stainless top mount manifold, dump and screamer/flanges/flex.
Turbo 4months old & still under warranty.
Fitted to vehicle and only for sale once engine sold!
$1250
Freddy RB25 inlet manifold & 80mm throttle body, modified to clear R32/S13 master cylinder.
Chrome outer and machined face, Tps & 3' intake pipe/hoses included
$450
Apexi powerFC suit rb25
Includes hand controller, Z32 afm & k/n pod filter.
Tuned by Pits - Rb25 with Z32 afm with 80mm throttle,750cc & Gt3037s with .63.
$1000
Nismo 750cc injectors in modified fuel rail with twin feeds.
$600
Splitfire coilpacks suit series1 R33 Rb25.
$350
Greddy GREX oil cooler kit
big cooler, thermostat and filter relocator, New Russell braided hose
$550
R32 40mm Alloy Radiator & 16' electric fan
$220
All parts are currently fitted to my R32 and I drive it everyday to work.
No dyno sheets, No tyre kickers & No bullshit!
Very aggresive and No knock even on 14psi
Heaps of quality R32 parts available!
Will sell all $5500 CASH and include spare RB25 long motor!
Gold coast
Sam 0423 648 114
Edited by 32TAXI
Story of the 25/30!
The old rb25 had leaky valve stem seals and smoked on hard decel, but still had even comp on all.
So weighted it up to rebuilt a 25 or 30 but scored a 30 Short block, collar, cometic head gasket, new waterpump and 2x 1.2mm restrictors cheap off SAU so it started.
Bought a spare 25 head, welded water passage and vct then got full reco and 2x valves by Gilberts.
Got a New genuine N1 oil pump and Nissan gasket set, Acl bearings and Moly rings from states at the right time. Crank was sent to Probuilt, Grubscrews and collar fitted, checked and linished.
Gave the block a good clean, drilled, restricted and a light hone(slight top ring wear)Standard bores, deck and crank, new dayco belt and hi/lo tensioners, RB20DET inlet cam/sprocket as always wanted GTR covers!
I'm a Mechanic of 15 years at Nissan, In the trade as they say and was built cheap so sell cheap.
RB25/30 was built in november 2011, No forgies, No rods, supported well, never spun over 7k or 14 psi.
Just a tough street engine that pulls hard, very aggresive and runs great.
Needs a good balancer as never got around to it & VCT can be fitted via external line or internal mod if needed.
Edited by 32TAXI
What sorta deal u do on engine and turbo?
Call, inspect and go from there
Edited by 32TAXI
Motor, inlet and box SOLD
turbo, powerFC, injectors, oilcooler, splitfires and rad all available!
Edited by 32TAXI
