Hey guys, need to run the self diagnostic on my R34, as I suspect my coilpacks are on the way out. As far as I am aware, the steps;
1. Turn ignition to ON
2. Connect the IGN and CHK terminals of the little box (e.g. with a paper clip) for 2sec
3. Check engine light (MIL?) should flash corresponding to whatever error code I have. 21 for ignition signal circuit I believe.
4. Repeat step 2 in order to "erase self-diagnostic results"
My query is about the 4th step. Essentially, does this actually clear the error code? Or just stop the self-diagnostic mode, so the MIL won't just continue flashing.
I.e. if I were to do the process again, would it still return the same error code as before (assuming nothing has been changed).
Just wanted to know in case I "clear" it but then want to run it again to double check the error code before doing anything.
Cheers for any input guys.
https://www.sau.com.au/forums/topic/405306-r34-self-diagnostic/
Can't edit first post; so typing this.
I'm an idiot! Of course it will clear the error code; however when the same problem occurs it will return the same error code once again as nothing has been fixed -__-.
Admins feel free to close LOL.
Also used my mates scanner instead; got error code 21; looks like my coilpacks are on the way out indeed.
Nah don't think it's misfired yet (or if it has, not too badly? Or I haven't noticed in any case). But light will come on usually a bit after driving (although if I've been driving, sometimes quite soon after turning on), and then I do feel some vibrations and engine sounds a bit off?
Also car is currently 96xxx... Seems about right for coilpacks bahaha.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
