i THINK xspeed was the only licenced place in Perth to do those computers and sadly for you (and others) they have now closed. There is a place in Sydney that does them but that is the only other one i know of in Australia.
dealer's are different unless the rules have changed. Anyone can be a dealer but to get the software to tune the hks comp is stupid $$, hency why (when i last looked) there was only 2 place in Aus that could tune them.
Do ring them any way you never know.
You may be looking for a new computer, mate. I had to sling the HKS valcon for my V-Cam, because it had been locked by the HKS tuner in Japan. The HKs guys in Oz were not interested, because I had imported the system on a second hand engine.
So I now have a Haltech that manages the V-Cam and everything very nicely and gives awesome results.
I know it hurts to throw away a perfectly good computer, but if nobody in Perth can do it, then that is your only option. If someone in Perth can do it, I would be cautious in dealing with anyone who is in a monopoly situation. They may well be fine, but you are at their mercy!
Cheers. :cheers:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
