Noticed some coolant on top of my radiator around the edges, does not seem to be coming from the centre. Futhermore i can here hissing noises coming from the raditor cap (sealed tight). No change in Engine tempreature and coolant level seems to be okay just wandering if these are signs thats its useful life is over.
https://www.sau.com.au/forums/topic/405446-is-my-radiator-about-to-cark-it/
Got pics of this? The cap could be stuffed and not sealing which will be a cheaper fix for you!
If you can show us where etc we should be able to help..... Whats the radiator look like in general? Any cracks or signs of fail?
UPDATE: turns out its a leak dudes being my bored self went down stairs to investigate the issue incase i missed something and barely able to see the little bubbling that happening at the bottom of the pastic of where the cap goes :domokun: this explains it, its a small leak nothing to bad, i think this means i need to change my radiator or find some type of sealent good enough to stop this little leak.
Dat alloy is tempting ill spray HKS in black on it (JKS), quick fix wont last long but just enough time for me to get cash and get in a new radiator, water pump and timing belt while im at it :yes: mech said he will need to take off radiator to the job so he can do the swap over while his at it, maybe save some coin.
Edited by starwarz
You'd be surprised how good the stock ones are.... I run 360rwkw and have no cooling issues and the race car (identical setup) does track day after track day and stock radiator ;)
Update: i have been searching the internet for aftermarket alloy radiators but so far all i find are Manual compatiable types, i hear you can fit the manual radiator along side an external transmission cooler. However i hear that its not efficent to have transmission hooked up to just an transmission cooler, it should only be used as a support mechanism for the actual radiator. Then again i hear that the R33 automatic is not hooked up to the radiator at all and is acutally running on this transmission cooler. So what do you guys think, will external transmission cooler along side an manual type radiator seem sufficient. If so how many rows should i consider i dont want to be sending my transmission to the grave.
Ill give it a go, changing it over does not seem like a difficult process might end up doing that myself. But im going to abandon manual radiator along side a external transmission cooler seems to be a very limited amount of information concerning that, it would be better to buy the proper radiator that can be hooked up to the transmission lines.
Edited by starwarz
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
