Yo yo yo yo yo.... hekkticc
Just more stock parts here and there from my car that I have replaced due to my OCD
Stock R33 Series II ECU Kick Panel
  • 1x Clip for the Flare is broken, hence I replaced it (I know serves no purpose but I replaced it)
Price: $5
Stock R33 Series II Mirror Control Switch (Should be same as Series I)
  • The bottom print on the switch is rubbed off, does show the open & close mirror print
  • Switch works fine, no damage apart from the image being rubbed off
  • I replaced it because of the image on the bottom being faded only
Price: $5
Stock R33 Series II Passenger Window Switch (Should be same as Series I)
  • Works fine, still decent condition
  • Button a tad faded compared to the rest of the trim, so I replaced it LOL
Price: $5
Stock R33 Series II Door Trims (Driver & Passenger)
  • Missing speaker grills (I bought these for the grills only)
  • No fabric sag
  • Tiny slight scratches on the passenger one near the speaker grill (barely noticeable)
Price: $70
Stock R33 Series II Hand Brake Level Assembly
  • Working and still on car
  • Comes with handle, and the cable that goes under the car
  • Handle looks like it was chewed off by some grisly bear then shaved with a bikini razor blade
  • Previous owner used electrical tape to sex it up, total failure
  • Suit someone putting it into another car or some project
  • Great if I knew how to remove the handbrake lever cover but I ended up getting a whole new assembly lol
Price: $10
Take the lot $80
Contact: PM or Reply here
Cheers,
Johnny
I will post up photos soon :)
SOLD:
- Door Trims
- Passenger Window Switch
Available:
- ECU Kick Panel $5
- Mirror Control Switch $5
- Handbrake Assembly & cable to undercarriage cable $10
SOLD:
- Door Trims
Available:
  • ECU Kick Panel $5
  • Handbrake Assembly & cable to undercarriage cable $10
  • 3 weeks later...
SOW Bump
SOLD:
- Door Trims
Available:
  • ECU Kick Panel $5
OR take the lot, 10x cans of degreaser
  • 4 weeks later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
