Hello good poeple.
Found an ecu on the shelf from a R32 Gts-t. It has been chipped/modified and ran aprox 180rwkw's on 17psi from stock RB20det. Only mods were FMIC, exhaust and pod filter.
Tune should be good to run on any RB20det but cant garantee that it would be safe, recommend visiting a dyno for a check up once plugged in.
$200 plus postage
Currently in SA, pickup welcome. Can even plug in if you bring your compatible car.
Cheers,
Daniel
Edited by =premo=
  • 1 month later...
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
