Yeah I could have had 3 complete bottom ends for nothing but I was a day late he had already thrown them out.
I have done everything so far, cheaper that way. Will leave the tunning of the haltech to Rob at Ried Racing though, but it wont be long and Ill work on learning that too.
  • Replies 43
  • 2 months later...
Floody,
If you like the passage, you'll love the R31 I might be getting if I am lucky in about 7-8 weeks. It's a GTS-X....RB26, Single T78 and all the bits to go with it, should be in the 10 second bracket. Will have to wait and see.
Floody,
Sounds awesome Scott, heres hoping you get lucky!!
I'll be hanging out to see that if you get it!
here's the list:
R31 - 1987 Skyline GTS
RB26DETT
T88 turbo
Trust wastegate
Trust FMIC
HKS exhaust and piping
OS Giken triple plate clutch
R33 GTR 5spd gearbox
HKS fuel rail
SARD injectors
R33 GTR fuel pump
Trust oil cooler
Greddy Profec B boost control
M's boost gauge, Greddy oil, fuel and exhaust temperature gauges
RAZO turbo timer
SSR 16" alloys
Bride racing seat
5 point roll cage - approx 650-700BHP
Sounds good to me.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
