Hey guys, I've searched here, google and eBay looking for the black pipe/hose going from one cam cover to the other on an R34 RB25det. Happy to buy even a universal silicon hose piece but seem to find that either. Guess I'll try a bit harder but in the mean time does anyone have a source for these? Would heater hose be ok for now? (mines gone rockhard and split really bad)
Any hose store?? Theoretically heater hose 'should' be ok, as it's mostly air with just a bit of vapour. But really you should get some proper oil control hose. I get mine from Hoseco. Otherwise Enzed, Pirtek, etc. etc.
Just go in and ask for 5/8 oil control hose.
heater hose wont work as the vapours going out of the rocker covers are hot and the hose will crap itself, as the hose is shaped your best bet is to get one from nissan,or you COULD get one from hoseco but you may have to buy a metre of it unless they have some leftover off cuts
Heater hose will work as a temporary solution is what I meant.
You don't need to use the formed hose, you can rotate the breather to suit any hose. No point paying out the ass for pre-shaped hose. You can also buy half meters from Hoseco. At $18 a meter it's not too bad.
Edited by Hanaldo
So is Siicon hose suitable for this? I can get the piece i need from Nizzbits for $35 delivered so I can use silicon and get it for 18 a meter like u said. Although I do like fitting genuine parts where I can.
go the genuine part if you can, the hose you can get from hoseco may or may not posses the heat resistance that you need. . .as a GUIDE i paid $18 for a breather (from rocker cover to rocker cover) hose for a R32 RB20DET from NISSAN. . .yes you can use heater hose as a very temp repair but why not fix it properly the first time?
It says it's for a RB20DET but those cam breather hoses look the same to me as RB25DET's as well (confirm the part # to be sure). http://www.kudosmotorsports.com/catalog/nissan-hose-blowby-genuine-nissan-skyline-r32-gtst-rb20det-p-581.html
whats wrong with heater hose? ive had it on my 34 for about 4 months now since i noticed the old one had split and i cant say ive seen any ill affects at all, ive taken it on and off half a dozen times since then as well, never had any troubles or noticed any wear or anything.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
