I'm selling my Walbro 400 LPH In-Tank Fuel Pump & Universal Install Kit. BRAND NEW. Still sealed in plastic & never opened or installed. The Universal Install kit contains Fuel Filter, Wiring Harness, Butt Connectors, Hose Clamps, Fuel Hose and Precautionary Statement Sheet.
$190 (New)
Pump Specifications
Overall pump length: 121mm
Main Housing Diameter.: 39mm
Lower Housing Diameter.: 50mm
Fuel Inlet Diameter.: 11mm OD
Fuel Outlet Diameter.: 11mm OD
Flow Rate: 400LPH @ 40PSI
Test Voltage: 13.5 Volts
Edited by GTR ZOAH
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
