not that I know of. RB26 always remained the same AFAIK. the way to tell was the lil buldge on the left hand side of the cam cover, I've never seen one on a RB26 even off an R34.
heh...
I think every single person (with the exception of the thread starter possibly) has mixed up Variable VALVE Timing (VVT), Variable Valve Timing and Lift (VVTL) and Variable CAM Timing (VCT)
HKS do make a VCT cam kit but it is very expensive (Andrew may dig it though!) - it was priced perhaps a fair amount more than say Jun cams.
I have not seen any car with it though besides HKS's own demo car and well... that's hardly independent.
If you believe the HKS spiel, response is greatly improved.
T.
well that pic is from Option mag, the car using it is a race car in Tsukuba. Basically the whole story was on V-Cams in this R32 GTR. Not tuned by HKS, was running HKS GT2540x2 Apparently it greatly improves the response of the car out of corners etc.
Its on Page 82 Option2 issue Jan 2004
What's the difference between VCT and VVT? Does one just change the duration and the other the opening time?
BTW I made a thread about this a while back but noone could help - does Nissan make ANY engines with variable timing, duration and lift? The SR20VET is the closest I've seen, but it doesn't seem to control the duration from what I can tell.
Cheers,
Michael
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
