Well this is my first post here, and decided to sign up after lurking for a little while and reading some useful posts, I bought my dream car a few months ago and it's a beauty, 1999 Skyline GT-T manual =) But I have a problem or two that I would like advice on if possible.
- On start up - the car screeches quite loudly, and then stops after about 1-2 seconds and you never hear it again until starting up again (it seems like the warmer the car is, the less screeching is heard) - I had it serviced last week and they stated it was the starter motor as they checked the belts/tightened etc. I'm attempting to find a starter motor for my car but am having trouble, is there any specific place to look or is there another possible reason for the screeching?
- Second issue I have is, the turbo has quite a noticeable whine when it spools - At first I thought it was maybe a hose leak but once again Autotune stated they checked and tightened the hoses (but I am not all that convinced). I tried reading on the whole "whining" noise of a turbo, and some people state it's normal and some state they are worried - I feel like I get good boost so not sure what's causing it.
Thanks for the input in advance.
Oh and one other note - where would be a relatively cheap place to get serviced in VIC (melb - northern suburbs).
Ps. Attached pic since I am new here =)
https://www.sau.com.au/forums/topic/406324-screeching-on-start-up/
the screech, if not a belt squeal, may be the starter motor sticking and not disengaging properly once you let the key go.
as for the turbo whine, it's not just the usual induction noise that you are hearing? maybe google a few videos on youtube of turbos spooling to see if any have a similar noise to yours
As mad082 has said; It could be the starter, often clutch dust etc, makes the starter shaft sticky, and causes the pinion to stick in the thrown out position, and if it stays engaged with the ring gear, you'll get a hell of a racket.
Flushing the starter shaft with contact cleaner will remove the stickiness, and no more screech. Opinions differ on whether a small amount of lube on the pinion shaft improves or exacerbates the issue in the long term.
Also; just "tightening"the belts is not always enough.
The tapered section of the belt lands use a "wedging" action in the pulley, even if the belt is not visibly cracked; the belt can wear to the point that the valleys of the belt can rest against the peaks of the pulley. You then lose the wedging action, and this will cause the belt to slip.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
