1989 bnr32 the car is in great original condition comes with genuine factory gtr key and nissan spare key (both with matching serial numbers) full documented service history from nissan japan/nissan aust.Ad08 tyres all round redline and amsoil used 83000kms a true collectors car 22000 ono
Edited by reni
https://www.sau.com.au/forums/topic/406937-factory-gtr32/
I just noticed on Carpoint its down to $19,900.00.......
http://www.carpoint.com.au/all-cars/private/details.aspx?R=13189160&YearFromShort=1633&__Qpb=1&keywords=&Cr=10&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&SearchAction=N&YearToShort=1668&__N=1216 1247 1282 4294963593 4294963846 1622 4294933125 1633 1668&silo=1011&seot=1&__Nne=15&__No=15&trecs=52&__sid=1391C0E143CC
I'm stunned it hasn't sold. Has anyone seen it in real life? Are there any issues? PM me if you know anything.
If I had a spare $20K I'd buy and park it. These things are near impossible to find in stock condition.
It has taken me 6 months to get mine to this condition and it owes me a lot more than the current asking price.
Cheers,
Bob.
https://www.sau.com.au/forums/topic/406937-factory-gtr32/#findComment-6505376
  • 3 weeks later...
  • 3 weeks later...
hey mate, The car looks very clean. Is there any rust?
Also thoughs fog lights near the front bar, they are aftermarket correct? Are they easily removed with no
damage, screw holes etc.
cheers ben
https://www.sau.com.au/forums/topic/406937-factory-gtr32/#findComment-6557737
  • 1 month later...
herb, have a look in car sales, was on there about 3 wks ago.
This 32 gtr needs a good home, its perfectly original.
The car is still on Carpoint and I'm buggered if I know why.
http://www.carpoint....id=1391C0E143CC
When I was looking around this time last year and bought my JDM in February, there was nothing but junk around.
I've spent a sh1tload on my car which I've finally finished restoring but it owes me bucket loads more than this car.
The longer it's on there, the more tarnished it gets. It's a shame because from what I've heard it's a good car.
Bob.
https://www.sau.com.au/forums/topic/406937-factory-gtr32/#findComment-6627921
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
