Hey Guys,
Up for sale is my auto 1997 Toyota Chaser JZX100, it has been much loved for the 7 months that I have had it. I bought it in Jan bone stock with some 19inch rims, that are still on the car. I have done all the modifications to this car. All work has been carried out at S-Garage and tuned at Chequered Tuning. The car now has 100,xxx kms, it had been serviced every 5,000kms and it is time for the 100k service, because I am after a quick sale, I will supply all parts to do 100k (timing belt, gaskets etc.) except oils, or if you supply oils I can do it. The reason for my sale is that I am on my P's and i travel far to go to work, and would like a daily. The car has usual scratches with age, and a common problem with dash lift. Apart from this the car has been kept in great condition, since in my possession it has never spent a night not undercover, and has always and religiously been filled up with 98 octane from BP only.
The mods are as follow.
Engine:
Greddy LS Spec FMIC
HKS Hybrid Hi Flow Panel Filter
AM Performance Dump and Front Pipe
HKS Hi Power Catback
Disabled ETCS
HDI Electronic Boost Controller
KTS Steel Intake Pipe
NGK Power Cables
Apexi SAFC Neo Tuned @ Chequered Tuning
Handling:
BC Racing BR Type Coilovers (Damper Adjustable)
Cucso Strut Brace
Interior:
60mm SAAS boost guage
Factory option Coin Holder
Kenwood CD/USB/AUX Headunit
Pioneer 1200W Sub
Exterior:
Eyelids
Factory Toyota Weathershields
Factory HID's
5000k Fog Lights
19inch Rims
Origin Roof Spoiler
30% Tint All Round
Guards have been rolled.
This sale is very regretful I will definitely be buying a Chaser when I'm off my P's.
Im asking for $13000ono with RWC and rego till June 2013, this will include stock cooler, exhaust, dump and front, stock suspension and the 100k kit.
I can negotiate price even more if you would like it on stock rims instead.
I am open to offers to swaps.
Once again a Perfect Daily or if you would like to strap a bigger turbo on for some more fun.
Contact me on 0431195777.
Ruben
I will take some pics in the coming days. This is a pic from a month or so back.
Edited by 93Q45
https://www.sau.com.au/forums/topic/407094-fs-jzx100-chaser-tourer-v/
Auto and sorry mate looking for daily, that I can run around!
Wheels are 19x8.5x35 wrapped in Traingle 245/35/19 tyres which are 85% all round
Also RED Blox Alloy Nuts
Edited by 93Q45
  • 4 weeks later...
bump price drop $12,500 will be doing 100k service today.
So nothing else to do, perfect daily.
Also has a Pioneer 1200W Sub with a double din Kenwood Headunit.
Edited by 93Q45
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
