Had a misfiring problem - took it to local mechanic who replaced one coil pack and the car was running well for 1 day then misfire returned. I used one of the diy tutorials to replace all coil packs. car ran fine for approx 40kms then started misfiring again - nowhere near as bad as they were misfiring before I changed all the coil packs but misfiring nonetheless.What could be causing this?? Anybody?
No, did not change plugs - they were all replaced about 7 months ago....(am checking them all today, though)
I went a bit cheap on the coil packs - FUJI Ultra sparks (sold by osaka.co.nz) ($345 for all six)
as above, weak coils prob fouled old plugs, just change them, haven't heard of those coils, maybe they're getting weak already, go for .8 plugs
(this isn't forced induction performance related haha)
Edited by WMDC35
Plugs are most likely covered in shit from driving around with f**ked coilpacks. Change them.
If your mechanic changed one coilpack, I would never go back there again. Unless you told him to quick-fix it and change one.
Its like buying one new tyre, or replacing one big end bearing, or one brake pad. Just stupid.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
