Nick wrapped for the first time.
He needs to get used to them, Max went easy on him
you can tell Max knows what he's doing with those wraps... good for me as they take some of the pressure off my knees... can't wait to have a crack at 200kg
Edited by NickR33
Australia Day 2007 I held my first comp, and I've had one every Australia Day since, except this one.
On that first one we had 8 competitors, here is what they squatted
Neil 90kg
Ghosty 105kg
Cory 105kg
Jovi 120kg
Adam 130kg
Simon 140kg
Herc 140kg
Benny 145kg
All lifts were PB's at the time, some by a long way.Move forward to 2013, heres who was in the gym squatting and what their squat PB is.
Rowdy 210kg
Zoran 225kg
Martin 227.5kg
Emad 232.5kg
Spiros 235kg
Daniel 240kg
Max 250kg
Jack 300kg
The strange thing is, with long arms like his he is supposed to have a huge deadlift and shit bench, like Fuzzy
The prick still benches 150kg
By the looks in his deadlift vid , Martin has a very strong upper back as well. He finishes the deadlift movement with some good power in the top range. That strong upper back is likely one good reason his bench is solid despite long arms.
Edited by rev210
