  • Replies 156
Was planning on making it. Family is double booked though. Unfortunately as my wifes' aunty isn't long for this world this could be the last chance to see her. Maybe able to go as far as Mt glorious and turn at the Samford exit. Hope to see you at 10. Seriously disappointed about the blue z32 not being able to make it. Was looking forward to drooling all over it (ex-Z32 owner)!
Would love to have you come by, even if it is just for a bit Craig.
Below are details so everyone has them on hand. If you can make it, can you please post up just so we know how many cars can make it.
If you are running late on the day or something has come up, my mobile number is 0403 844 395. - The number is publically available, so don't really care about posting it up. :)
Hi guys!
See below for details of our next "awesome-ness filled V/Z/M cruise" meet.
Date: Saturday 29th September 2012
Time: 1000 through till early arvo unless people want to hang around
Route: http://goo.gl/maps/5pUCR
Hope to see the regulars as well as a few new faces.
Please post up your attendance so we know who will be there.
Cheers,
Tony
Yeah I can lead no worries. I have a couple of 2 ways to bring but we can swap numbers before we head off too. Mobile reception is a bit dodge in places.
If someone who has a 2way can stay at the back of the group we won't lose anyone. Or give a 2way to whoever isn't in a hurry and wants to stay at the back ;)
I'll stick around the middle. Sedans can only go so fast, especially with a child in the back (he loves Skylines and cars in general so he'll be squealing like a piggy). Should be a good run. Can't wait! Looks like we can expect about a dozen cars. ;)
1: Tony
2: MagicMike
3: Amrit
4: z32
5: z32
6: z32
7: z32
8: audi TT
9: possibly 1 x moto since his z32 is being built
Waiting for the z32 list to be updated.
Edited by MagicMikeZ32
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
