New HKS Garrett 3037 or 3076 Turbo
The GT3037/3076 is an exceptional turbo for its HP range. It features a .6 surge slotted comp cover and a complimenting turbine/comp wheel ratio, making it a great bolt on upgrade for the 2-3 litre range engine
Got my HKS 3037 upgraded to a 3582 so the Brand new 3076 CHRA ‘core’ from my turbo can be put in a new housing by Hypergear in .82 turbine and .70 comp (may be other options too if this doesnt suit). If you need exhaust housing i can prob sort that out too.
Good for RB20/25s, SR20DETs etc
Price: $600 for CHRA, $1100 with housing, not sure how much with exhaust, depends on type.
Any offers let me know :)
https://www.sau.com.au/forums/topic/407827-new-hks-garrett-3037-or-3076r/
so how many rear housings do you have?
None, Hypergear will put the CHRA in the housing that is compatible with it and that suits the buyer as with the exhaust housing :)
So will all be new , i thought it would be easier to sell that way than a CHRA by itself.
Is this a 52 or 56 trim comp wheel?
So is the $600 price no comp cover?
56 i think... according to this site anyways
http://www.rhdjapan.com/hks-gt30-series-turbo-gt3037s-22353
$600 is CHRA price, $1100 for housing and CHRA, $1400ish for exhaust housing i guess.
Assuming original comp cover has 3" intake?
Is it new?
I'd like to purchase the CHRA only if so.
Please PM me your mobile number and photos of the CHRA tag please.
Thanks
OM sent
Yes brand new, never taken out of plastic bag
CHRA can be sold by itself
i took pic of turbo tag, i dont have the CHRA, its at hypergear , I can call and ask for it
Just want to add some thing. In side that big box that I've sent every thing back with. The 3076 core was contained in a solid small box inside the big box. Don't throw that away. Every thing sent in has been sent back to you.
OM sent
SMS Sent
Can I get him to send it to you and you verify it as being received before making payment, I will send some housings to be machined/fitted to the CHRA by you...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
