AAAARRRGGGG.
Best run was 12.105 @ 126 mph
I missed gears ( 2nd to 5th is not a good thing), still stupid amounts of wheel spin, I then was given the good word to start in second which would have worked better with more revs as I stalled launching off the line.
I eventually got a good run on my last pass, started in 2nd, launched at 6000rpm, it felt good till I got some wheel tramp, still it was my best launch and time.
My next time out should be better still as Im starting to get the hang of it, I just need to slip the clutch a little longer instead of getting off the throttle as I think this is what caused the wheel tramp.
Over all a fun night.
11.99999999999999 next time maybe !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
At least Nick had some good times.
Mark, how'd that last run feel, it looked better, no stall at least :nyaanyaa:
bit slow off line then some wheel spin then gone
Thanks for the tips mate, Im sure with some more seat time Ill eventually get there.
Ohhhh Mark soooooo close!!!!
I had abit more luck then Mark first run was an 11.9@118mph I was stoked with that then 2nd run punched out an 11.622@119mph
Got close to it with an 11.67@120 then 11.7 and an 11.8
For some reason boost wouldn't go above 1.4bar when it should be 1.55 so confused about that one but all in all car performed flawlessly and very happy with the results
Tyres used were 265/35/18 Michelin pilot super sports
that's it mate, more practice and that 11 will come, you have good mph
do you think the second gear launch was better traction wise and with a few runs more do you think it will work for you
60" time on the last?
The 2nd gear launch felt much better BUT the 60 ft was 2,347, the wheel tramp put me off as it gave the car a good shaking at the top of 2nd gear, I thinkl I backed off a bit and it started to tramp, I should have kept up it in hindsight, time will tell.
Did it look like I had the right revs on launch?
yeah it looked much better, to me it looked like your clutch motion/timing was a bit off though, bit slow to get to the friction point then a bit to fast off the rest, which results in rolling off start line for a few meters then excessive wheel spin, your car clearly has the torque to pull second no worries it's just practice, and 6000rpm in second looks the money
maybe look at slightly stiffer shocks, your squatting a bit fast and it looks to be hitting the bump stops
well that's 3 beers time for bed
So close mark, let us know when your heading out next.. Hopefully when I'm back!
Nice work Nick, what power is your car making now?
Making 350-360awkw that's at 1.55bar tho was only for some weird reason making 1.4bar tonight so say 340ish tonight lol who knows :P
Im going next week :) lets see if i can get a 11.5 this time.
Nick ma man. Need to nail those 60' times man
Even with your "low boost" thats a low 11 sec car
Yea probably had wrong tyre pressures not too mention the circuit set up I'm running but still very happy with the result
And my ham fisted driving hahahaha
Lap times are what I'm after ;)
Time to get yours out on track!!!
I agree Nick you need to work on your 60's. Back in the day (before my flywheel turned to dust) I was doing 1.6's on worn out Nankangs with less power. You have a solid 0.25sec ET to gain just on improving your 60's.
Yea you are right im sure with some more practice i could get it alot lower but for me anyway straight line gets a little boring
dont get me wrong its good fun but not what i built my car for
It's great practice for the track. Gear changes and throttle control play a big part in 1/4 mile and show massively in your ET. Transfer those skills across to a 2-4km circuit and you can see how much time can be gained/loss just in gear changes alone.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
