  • Replies 103
Are they both using the same turbo's?
Obviously if a turbo is at the edge of its efficiency then a set of cams will do wonders, cams reduce the amount of boost required to flow x amount of air.
To make more power you can either use a larger laggier turbo or start looking in to improving air flow in to the pots.
No, there not using the same turbo, I have a GT30, and robs is the TD06. Even he will agree that his is laggier than mine.
The point that we were trying to make is that SK comment
My experience has been that the standard camshafts are the most likely first limiter over 250 rwkw. They simply don't have enough lift or duration to let the air into the engine. Sure you can turn the boost up and try and squeeze some more air in, but you will get higher inlet air temps and lower efficiency.
doesn't always hold true. On stock cams mine has made 330rwkw and still hasn't fallen off at 8000rpm. That's not to suggest that most RB25's don't do what SK suggests though, but cams may not be the only restriction.
I haven't had any port work done yet. just want to see how far I can go with the stock cams.
and its still using standard injectors and cams?
We're using GTR injectors now, although we could have got the stockies to this level, we knew that seeing as we're pushing for 500rwhp that they wouldn't last. Just need to fit an 044 pump as I'm sucking the pump dry:(
GTS-t Vspec,
You are definately missing out on not having some higher lift/longer duration cams in your engine. You will make more power and the inlet temps will not be as high, it's just physics. There are always two ways to make good power. So far you have chosen the hard way trying to see how much power you can make on standard cams. For the rather small outlay you could pick up so much performance. I'd like to see you crack a 12 second pass, you've been waiting so long for it so I reckon you should treat yourself to some nice camshafts :P
GTS-t Vspec,
You are definately missing out on not having some higher lift/longer duration cams in your engine. You will make more power and the inlet temps will not be as high, it's just physics. There are always two ways to make good power. So far you have chosen the hard way trying to see how much power you can make on standard cams. For the rather small outlay you could pick up so much performance. I'd like to see you crack a 12 second pass, you've been waiting so long for it so I reckon you should treat yourself to some nice camshafts :(
Dave, Sure I could put a set of cams in, and make alot more power, but I just wanted to show that it's not necessary to make decent power and not run out of puff at 6500rpm. I'll do an 11sec pass with stock cams just for you;)
You go for it, it's not the way I would do it. But hell, give it a go, maybe you will be the first person in the world to do an 11 on standard cams. :( I really don't know whether anyone else has ever done it. I do know a black R34 GTT that did an 11.6 with 50 bhp less than you. But it had 260 Tomei Poncams in it, so it doesn't count.
But on to more serious matters...
the engine had only been rebuilt 2 days earlier
What happened?
I have no doubt of its potential.
I cant pull on it with 4 people in my car yet i can easily walk away from other reasonably quick cars(low 13's etc) as if they standing still.. once again with a full load.
What speculation you want on his HP.. if you'd see it you'd believe it.
THing is Sydneykid is we have cars out there,You rewrite other PPLs storys as your own.
Facts Steve, I only deal in facts. And the fact here is the R34 GTT did an 11.6 with 50 bhp less. Whether I wrote the story or someone else did is irrelevant.
i seem to recall use of slicks.. and bits breaking..
Yep summoner 50% correct, my suspension set up got the traction and squat so good that a driveshaft became the weakest link. But the fastest run was on Nitto's, not slicks.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
