hey fellas thinking of wrapping my r33 bonnet in matt black, beacuse its cheaper and more legal than a carbon fibre one!
anyone done this? be keen to see what it looks like, tried google but cant find a picture.
ive got a white s1 with spem m bar.
https://www.sau.com.au/forums/topic/408742-matt-black-wrap-on-r33-hood/
wow that was helpful.
ill reiterate..
has anyone done this to a white 33, if so could you show me a picture.
i have searched and googled but cannot find a WRAPPED bonnet on a white 33.
thanks in advance for your help.
Well maybe google "vinyl wrap close ups"?
Don't limit your search to bonnets/R33s.
thanks taylormade.
already done this but i would really love some pictures or advice from people that have had it done on here.
god knows why. when any one asks for advice all they get is shit.
really wanna see and hear what r33 owners think,
the whole point of asking is so i can can physically see the quality of a wrap. not deal with a keyboard warrior.
No, you asked if anyone had black wrap on a white R33 bonnet to see - Be more sepcific, and greatfull when people are trying to help you.
Quality of the wrap will depend on who does the job,
http://carbonfibrevinylwrap.net.au/ - Good reviews about this mob.
thanks taylormade.
well im an R33 owner- and soon to have a full matte black wraped R33.
mate you were not trying to help you where being smart.
you had absolutely zero positive input,
i was very specific in asking for a matt black wrap. NOT carbon fibre. anywho cant be arsed arguing. so lets forget it. good look with your wrap pretty keen to see how it looks.
yer anywho...... I hope its looks the goods too. My mate is manager at signarama here in sydney cbd- Rekons they use the same 3m wrap as do most companies - hopefully i can get it all wraped for $1500 or under.
I will upload some of the work they do when he sends them through- he done his speed boat last week and it was unreal.
ive always wondered about the heat from the engine bay aswell, i know this stuff is durable - but to what extent.
Also i would think that any dents in the body work would be a hassle for creating air pockets
Edited by sydking
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
