Hi guys. Just as the title says, I've got an RB25DET in my R32 and whatever I do, the boost will NOT stay steady.
The motor is 100% standard. Standard turbo, intercooler, dump pipe, blow of valve, everything.
I have tried a few configurations though and nothing makes any difference. Have tried an RB20 actuator, t piece boost controller, aftermarket dump pipe and just recently a brand new GReddy Profec B Spec 2.
So like I said, even with stock parts, the boost level to 4000rpm will stay steady at 4.5ish psi, then gradually climb to about 8.5psi by redline.
It does it in every gear, although I found if you launch hard in 1st then the boost stays down a bit for some reason.. Whereas if you're on the freeway in 3rd or 4th then it will climb more noticeably.
I have checked the wastegate flap and moves very freely and does not get stuck at all.
What the hell is the problem?!
I've tried two different standard RB25 ECU's, both have the same affect.
The car is standard. Fully standard. It has to be something broken or not functioning correctly, but what?
If the actuator isn't opening properly then he would be having massive boost spikes. Would be more a case of the actuator not holding closed properly but then like someone posted above if he is still running the stock boost control solenoid then it could just be normal
The solenoid is non existent and the actuator and wastegate are both working CORRECTLY. The actuator has also been swapped out for one which has been proved in another car to be working properly.
Today the car stalled on me while coming off higher revs and putting the clutch in. To me this indicates a leak of some sort. I am getting a smoke/leak test done this Saturday to see if that is the case. The turbo to exhaust manifold gasket is brand new and there are no leaks there. I'm thinking the leak may be coming from the actual manifold to head gasket...
Smoke test came up sweet. Noticed the TPS was stuck on 0% according to ecu. Checked and found the signal wire has a short to ground. Ran a new signal wire now TPS works.
Ran it up on the dyno with boost controller turned off. Ran 5psi then creeped to 8psi up top 177kw
Tried playing with boost controller with no rise in boost.
So
Turned it onto high boost and held a flat 10psi 201kw.
Next run te same. 3rd run boost dropped back to gate pressure. Suspect his boost controller is faulty
And Jez has done it again. Car now runs perfectly!
I completely removed the Profec B and switched back to the RB20 wastegate and now the car holds 10psi all the way to limiter. Stoked :D
So it looks like for some reason the RB25 actuator would not hold the same pressure (although I had the same result with another RB25 actuator), the 'brand new' boost controller was faulty (will have a word with who I purchased this from), and the TPS wiring (I had the R32 RB20DET > RB25DET loom made up by someone reputable) were all significant factors as to why my car would run how it did.
Other things which improved with how the car drove were brand new AFM and OEM o2 sensor.
Was definitely a bitch to get this motor running how it should, but worth it in the end.
Thanks again Jez!
Edited by Brent
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
