so, ive got an os giken twin plate clutch for sale.
suit push type rb.
has been rebuilt approx 4-5,000km ago.
has seen some launches.(lets not kid ourselves)
clutch plate centres are os giken, puk style.
good for around 600hp, drives suprisingly well.
not too heavy, has a bit of bite, but you get used to it.
moving to a box with a holinger input shaft.
$850.
sorry, dont want to post at the moment.
also have m's pods to suit gtr.
with filters(k&n style).
$100
r32 gtr gearboxes x2
1x just came out of running car.
does crunch when shifting fast to 3rd and 4th
sounds like it has straight cut gear set, IT DOES NOT!
comes with transfer case.
no shifter included.
1x bought 2nd hand.
unknown condition.
$400ea, or make an offer.
will add more as i find it, upgrade it....
pm me on here for more details.
  • 3 weeks later...
  • 4 weeks later...
  • 3 months later...
price drop!
twin turbo pipe with splitter welded in, 150!
THATS INSANE!!!
gearboxes now half price!
get these rebuilt whilst still driving yours.
  • 1 month later...
  • 1 month later...
  • 5 months later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
