Can anyone recommend a place for a cheap headlight ballast replacement? New or used?
The car is a 2003 V35 but has after market headlights. Although I think this is a standard ballast? Drivers side if that matters.
Pics attached, any info would be greatly appreciated :)
Edited by CAT_SPEW
https://www.sau.com.au/forums/topic/409281-v35-headlight-ballast-replacement/
Hey Matt,
So you have HID's right?
http://www.ebay.com....=item53eeab1e3b
That's pretty expensive though just for 1 ballast when you can buy this full HID conversion kit for $169 that has 2 ballasts
http://www.nlmotoring.com/ONEX-HID-Xenon-Kit-H1-p/onex-hid-h1.htm
Edited by Seano350GT
Hey Matt,
http://www.nlmotorin...onex-hid-h1.htm
Thanks for the quick reply mate. I was hoping to get something local 2nd hand to save a bit of money but I'm not sure if that's going to happen.
Pretty sure they are HID lights, just bought D2S 5000k bulbs thinking that one of mine was blown but it turns out it is the ballast from what I can tell. There is power going into it but not coming out the other side.
I actually just came across the below ballast which should work for me? Although I may need to stuff around with the wiring a little bit and leave the old ones in there to seal the lights.
http://www.ddmtuning.com/Products/Replacement-HID-Ballast
http://www.ddmtuning...ent-HID-Ballast
Hmm, i have never seen one of those before.. No doubt an electrical guru will comment pretty soon though :)
that DDM one will not fit the headlight, it will then need to have the neg and positive wired to the battery, so it can work but not oem...
The first link is also not OEM but will fit much better than the 2nd link
Edited by R6n350GT
PM replied mate, if anyone else has a stock ballast they want to get rid of please PM me.
Ill have some OEM ballasts of a sedan soon. Wont have the globes tho because im doing a stag nose and the Hid globes are cracked. But i dont know how to pull them apart so ill just send you the whole light if your keen?
hi all, i would like to know how do i check whether my v35 has HID or not, i dont seem to be able to locate the ballast anywhere under the bonnet. but low beam is crystal white (just like a HID), and high beam/ driving is yellow as standard.
now im planning to get a HID KIT, i would like to know where can i get the best HID kit possible. 35w vs 55w ? which should i choose? and how do i check if v35 uses canbus system or not ?
I believe all of our cars are manufactured with HID's but they should have been removed and replaced with xenon halogens on compliance (but some people have been lucky and got away with it) the ballast would of either been kept in the car with the wires cut or completely removed. So in saying that, you should be able to slap a HID ballast in there and connect some bulbs without and dramas. I found a good kit for about $165 but its not OEM http://www.nlmotorin...onex-hid-h1.htm
If you have a 'crystal white' light on low beam, chances are the low beam HIDs were not removed at compliance. it is possible to get halogen lamps with a blue coating on the glass to make them look 'white' or even 'bluish'. The easiest way to tell is HIDs will be a little dull when you first turn them on, then brighten up after a few seconds.. Halogens come on at full brightness instantly.
to replace the high beam/fog light properly, you would need a H4 Bixenon HID kit. Unless you want to ditch the fog lights and just have a high beam.
Our cars do have canbus, but I can't see why there would be any difference with HID kits, as the BCM drives a relay, and the relay powers the headlights.
