I have a pair of R32 GTR front seats. Drivers seat is torn in the usual spot. Apart from that it is in fair condition. Passenger seat in good condition with no rips or holes. Has a few faint marks which would come out with a steam clean. Selling as a pair.
I also have a set of R32 GTR wheels. 3 x wheels in good condition. 1 x with gutter rash. Tyres are still on wheels however they are snow tyres and no good for our roads.
$400 for seats (NEGOTIABLE)
$350 for wheels.
https://www.sau.com.au/forums/topic/409298-r32-gtr-front-seats-and-rims/
  • 4 months later...
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
