well as i ve just moved up hear cool ? ive come in to some money with my new job ? so i have done just a few mods to my red gtst 33 , like i droped in fully rebuild with al hks gear RB26 running single turbs motec ecu ect ect motor was fully build by bd4s and all coast me under 17 grand we put it on the dyno today and got a whopping 412 hp at the wheels and ggggggggggg feel great on the road and its a real pig to drive but i love it now ive got to find money to up grad the brakes and stp it from bounceing all over the road as im keeping looking stock so i thought i would sher this great news with my new found friends come and say hi some time
https://www.sau.com.au/forums/topic/40931-im-in-the-412-rwkw-yeha/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
