I have a set of Brand New Genuine R33 GTR Series 3 Xenons, I bought these for my road R33 GTR which I have since sold. Will be a total waste to put these on my track car.
These are complete with ballast resistor and bulbs.
$2,000
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
