This has been a build that started almost 2 years ago due to lack of time and $$. This is going to be heavy on the pics and light on the words as im not big on words..
It all began when i was looking for a car and came across this A31 in below average condition but well priced. From memory i paid $2400 for it with 5 months wof left & 6 months rego so just decided to drive it untill it ran out. The plan being in that time i would find a better shell and swap all the gear over. That proved harder than i thought it took almost a year to find what i wanted .
This is where it began. RB20DET, Manual, Lsd etc etc
By jdmyo at 2011-12-27
This is the replacement. Im the 2nd NZ owner, an old guy owned it for 17 years and i only got it because he passed away.
By cefiro at 2011-12-27
This is the engine out of the origional car.
By jdmyo at 2011-08-19
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/
  • 3 months later...
It was all a bit of a dulux rebuild
Some new parts..
Pulling the motor out and preping the engine bay
Waited a week with the heater and dehumidifier going for the paint to dry.
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687613
Didnt think of cutting the holes for the I/C piping before painting so had to do some careful drilling. Also swapped rear hicas subframe for a non hicas one.
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687614
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687618
When i got all running the turbo oil seals were leaking and it was smoking like crazy + the exhaust was rangi as.
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687620
more exhaust and some pics of when i took it to Powercruise in Nov
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687621
A couple of things i had to do for the cert.. High flow cat and 2 hoops + changing an exhaust that had done about 200kms.. Should have done my research.
By cefiro at 2012-02-25
Got some strut braces..
By jdmyo at 2012-02-26
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687622
Stripped block, had a massive time getting the inner crank pully off. Consumed about an hour of my life due to rusty build up. Everything looks alright rings look new, bearings a little worn, still has hone marks on bores but i think they are factory ones..
Im going to get my engine rebuilder to relocate my tentioner bearing as i dont want to fail. I will also get him to fit crank collar. I will give the bores a light hone myself.
By jdmyo at 2012-03-04
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687627
Got all the parts back from the engine reconditioners yeaterday. block, cradle, crank, pistons, rods, pick up all acid dipped. Crank polished & collar fitted. Piston ring groves cleaned, shot peened & gudgens checked. Tensioner stud repositioned. I will fit the oil restrictors myself. Got all parts except bigend bearings which will arrive mid next week. Will give it a light hone this weekend then start putting it back togeather..
By jdmyo at 2012-03-14
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687628
Gave the bores a light hone/de-glaze. Dont think it came out to bad having only done it once before. Got the crank and pistons in as well.
By jdmyo at 2012-03-18
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687629
Started on the head yeaterday. All well except the bolts in the exhaust cam keepers where seized in the keepers. Unknown why or how but got them out by very slowley unwinding them bot cant get bolts out and damaged one trying. Yay get to spend more money getting more. Other than that gave it a good clean, very light valve lapping with some fine paste.
By jdmyo at 2012-04-21
https://www.sau.com.au/forums/topic/409901-a31-on-a-budget/#findComment-6687632
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
