Hi guys, due to certain circumstances I need to sell all my gear for my gtst.
Items are located in the Hunter Valley NSW but can be posted at buyers expense or by other arrangement with myself.
Purchased a brand new set of Tomei Poncams and springs earlier this year from Nengun. Items are still brand new in the packaging they came from japan in
Cams - Nissan - Skyline - ECR33 - 8/1993-9/1997 - Duration: IN,EX 256 Lift: IN,EX 8.5mm
Springs - Nissan - Skyline - ECR33 - RB25DET - Type A - Lift 8.80
Purchased these brand new for $1300 - wanting $1200 - No need to wait a week to recieve them
Nismo Coil over suspension for R33 GTST - Front and rear. Damper Adjustable only. Still in brand new condition, never taken out of the box. - $1000
Apexi Power Fc with hand controller - used. $1250
Z32 AFMS - purchased off another forum member from his GTR - has twin to single adapter. No plugs - $250
Willians 4 point harness, still brand new and never used. Out of date for competitions tho - fine for street use - $100
SSR Integral rims - I think these are copies but unsure. 18x8 +30 offset. comes with 4 tyres. most still 80% 1 %20 - $750
Stainless Steel Catch Can - $50
Front Bar to fit Series 2 - Is a fibreglass but told its original - painted in grey colour. - $400
Fog lights for Series 2 - $200
Can either contact myself via SMS - 0416294030 or email [email protected]
https://www.sau.com.au/forums/topic/410050-r33-gtst-performance-parts/
Purchased these brand new for $1300 - wanting $1200 - No need to wait a week to recieve them - Price Drop $1000
Apexi Power Fc with hand controller - used. $1250 - Price Drop $1000
Z32 AFMS - purchased off another forum member from his GTR - has twin to single adapter. No plugs - $250 - Price Drop $200
Willians 4 point harness, still brand new and never used. Out of date for competitions tho - fine for street use - $100 - Price Drop $50
SSR Integral rims - I think these are copies but unsure. 18x8 +30 offset. comes with 4 tyres. most still 80% 1 %20 - $750 - Sold
Front Bar to fit Series 2 - Is a fibreglass but told its original - painted in grey colour. - $400 - Price Drop $300
Fog lights for Series 2 - $200 - Price Drop $150
Edited by KamikazeR33
