are GT-t fronts the eyelet type? and are you after factory standard struts and springs? if so i have a good set of front OEM struts and springs with about 70,000ks on them, no noises, creaks, or leaks, just PM if its what you're after
cheers
dan
Edited by squareznboxez
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
