Whats peoples experiences with them? I seem to be hearing a fair amount of negative feedback towards them slipping. Need a half decent clutch ASAP. Rang NPC and they quoted me around $1000 for a cushioned button rated to 400rwkw and a flywheel for another $400.
I didn't really want to spend anymore than around $600-$800 on a clutch to hold 300rwkw.
Thanks.
https://www.sau.com.au/forums/topic/410705-exedy-clutches/
I toasted my Exedy clutch! (pics in build thread of you want lolz :laugh:)
Drove a 34 with NPC cushioned button, heavier pedal that the Exedy and bites harder etc... Not bad!
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561741
NPC ftwbbq
Ask them for the 10" sprung button clutch and flywheel. Or if your being cheap, just get your flywheel shaved. $700 for the clutch.
Your getting sloppy man!
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561756
I kind of wanted to keep good drivability because its a street car :/
Then go the cushioned button... Takes about 3 seconds to learn and is only $850 or something
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561838
300rwkw? wtf do you need any special clutch for?
NSK-7056HDCB - Exedy Cushioned Button....off the shelf.....will hold 300rwkw. You don't need the flywheel.
Done
Yeah did me well.............. Not :P
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561911
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
