hey guys
Okay so looking for abit of feedback and advice on this one.
(rb26 from r32)
So the rb26 standard runs 440/444cc low impedance injectors with a standard resistor box inline.
On my setup/build I have installed/upgraded the injectors and rail, and am now running 1000cc low impedance injectors, and also
full wire in aftermarket ecu. so we arent using any of the standard wiring to the engine itself obviously,
So what im wondering, is it possible to just wire in and use the old resistor box for the new setup? And if not why is this so.
Or shall i need to install aftermarket resistors and calculate to accomadate the feed?
I am aware that some aftermarket stand alone ecu's have the option built in to switch for low/high impedance, but in this case
what im using doesnt.
I figure it would be alot cheaper,quicker easier to wire in the old box, then to make sa resister panal up and mount it, (preferably in cabin away from the heat.
thanks
https://www.sau.com.au/forums/topic/410941-upgrading-injectors-on-rb26/
hey guys
(rb26 from r32)
thanks
Depending on which ECU you have chosen, you won't need the resister block.
Most aftermarket ECUs will peak hold injectors for low imp etc
Make sure the injectors are low inpedance.
I had a set yesterday from' five o' from ebay that are high impedance and i actually had to remove the resistor box.
If u need to leave the resistor box in due to low inpedance than its as simple as changing the injector plugs to suit ur new injectors
okay thanks
Yeah im running a g4 LINK ecu, they will require the resistors.
yeah we ran a meter across the injectors to check the impedance.
Thanks Dan, i actually had my oil pump fitted with the new billet gear by you guys, and bought some oil restrictors from you about a year ago :)
yeah i have the stock resistor pack in the old loom, so hopefully i can just wire that in instead of making a new resistor block
Yes it will be very simple to wire in.
Its simply 12V into the resistor and then theres 6 power wires to run, 1 to each injector
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
