Genuine WALBRO 460LPH E85 Fuel Pump
- Most popular in-tank performance fuel pump on the market today
- 460LPH flow rate + E85 compatible (purpose built)
- Standard 38mm fuel pump design
- Can support upto 950HP at 13.5 Volts
- Genuine WALBRO – manufactured in USA by TI Automotive
- Comes with 2x strainers and everything pictured - OEM # F90000267
++ Comes with a free Delphi wiring harness (male plug) ++
$295 $235 incl. Express Delivery << SAU Special
* This is an Australian delivered product with a national warranty.
  • 5 weeks later...
  • Replies 59
how much will this support power wise ?
Hi,
It's designed for engines exceeding 500HP as quoted by Walbro.
- Brendan
im also keen to know about this?
I've had a look on there website and there is no technical specifications of the sort on there.
I would say google it.
ok so how can you sell it as a purpose built E85 fuel pump if you cant answer as to why?
This is a Walbro fuel pump that is intended for use with E85 fuel, I am not aware of the exact reasons that make it E85 compatible. You are welcome to contact Walbro for technical enquiries of this sort.
  • 2 months later...
Received mine today, awesome price and super fast delivery !!
Thanks
Lol we should probably bump the price up on these :D
Enjoy the pump!
Do you have the male ends of the plugs with these or is it a standard Bosch type plug?
Hey,
It's just the standard plug as pictured above, you can get the male ends online as well.
- Brendan
are these universal kits? or model specific. got anything for a evo ct9a?
Hi,
Na just universal comes with 2x strainers and everything you see in the image.
Nothing specific for the EVO's yet.
- Brendan
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
