-Name: Jamel Lopes-Hurt
-Email: JDIZZY204 (AT) GMAIL.COM
-Phone #: ZERO EIGHT ZERO THREE EIGHT THREE ZERO ONE THREE THREE ZERO
-Postal code: 550-0013
PM me or email me for quickest response. Thank you.
I am selling a silver set of SSR meshies in 17x10.5 -19 17x11 -13
These are wheels are the Holy Grail of 4 lug fitment. 5 inch lips all around and extremely aggressive offset. The wheels are in almost perfect condition with minor curbing on 2 of the wheels. There are no cracks nor bends at all. They will be sold without tires.
**Cheap people and lowballers, do not bother messaging me!! I will not entertain offensive offers!!!**
NO TRADES!!
I am selling them for 240,000 JPY SHIPPED (~3000 AUD SHIPPED) and PP fee.
Yea, these would not clear big brakes without a spacer . Would suit an Old school Skyline or fairladyZ very well
Edited by vipv35
Yes I marked them up but clearly you have no intention of buying them and prefer to thread shit. I know what the wheels are worth, the previous owner did not.
Edited by vipv35
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
