HKS FCon V-Pro ECU 3.24 and Patch Loom to suite Nissan Neo RB. Includes Fcon Navigator
$500
Tech Edge 2J1 WideBand o2 Kit.
Bosch Sensor, Gauge and Controller. Has serial port for data logging. Can hook to AUX in on aftermarket ECU for WideBand monitoring.
$200
Turbosmart eBoost 2.
One segment on the LCD is dead. Works fine.
$300
HKS TwinPower DLI2 for RB (Came off Neo, will fit others)
$400
Defi Link Gauge set.
52mm Oil Press, 52mm Oil Temp, 52mm Exhaust Temp, 60mm Boost, Control Unit. All wiring and sensors included, some cups included.
$800
Pics here: https://www.facebook.com/media/set/?set=a.10152175129295352.918879.666155351&type=1&l=cd18df02b2
Edited by Mitch_Rona
FCON sold.
eBoost sold.
HKS Twin Power DLI2, Defi set and wideband kit still available.
Also have:
RB26 HKS style high mount T4 exhaust manifold with 60mm HKS style external gate with screamer available. Used but in good condition $250.
Turbonetics GTK-650 turbo. Used but good condition. $500. or $700 with above manifold and gate included.
Sard 800cc Injectors. I'll throw in a RB26 fuel rail. $450
Turbonetics GTK-650. I'll throw in an oil feed line and a drain fitting. $500
RB26 HKS type High Mount T4 Exhaust Manifold, with 60mm HKS type gate and screamer pipe. Used but good condition, no cracks, served me well. $250 (or with turbo $700 total)
Defi Link Set. $800
HKS Twin Power DLI2 $400
TechEdge WideBand O2 kit. Aussie made. Has outputs for data logging. $200
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
