So I disconnected it and now when I hit full boost it is going higher than before. Haven't changed any settings. Any thoughts to why!
What settings do you have it on, high or low ?
I disconnect my battery all the time and I have never had a issue, I ve disconnected the control twice as well moving it position on the dash and whilst installing a remote high/low boost switch.
It's on high. I never change it. It only going over by 1psi but still shouldn't be doing that.
