Coupe or sedan?
I have a JIC Magic Spartan DE I bought from their reseller (Bullet exhausts) in the US.
Look on ebay. Its pretty cheap, mine was under 800 delivered
I'm really happy with it; except my compliance cats made my exhaust a little bit shorter than it should... makes the fitment a bit off.
Going so sort that with some high flow cats eventually.
https://www.sau.com.au/forums/topic/411473-exhuast/#findComment-6577714
http://www.ebay.com.au/itm/JIC-Magic-INFINITI-G35-2door-CVP35-OVAL-SUS-Exhaust-/330451322538?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cf06f06aa#ht_897wt_1165
I really like the sound; it isn't very droney (except for when the rear clamp leaks; but as I said, that;s because my compliance cats have shortened my exhaust by several inches)
https://www.sau.com.au/forums/topic/411473-exhuast/#findComment-6577910
depends if you want a cannon on the back or not...
cheapest option is to drop the midpipe and get an exhaust shop to knock up a straight thru pipe
or listen to the difference in setups i made at home
http://www.skylinesaustralia.com/forums/topic/409286-dual-exhaust
if you can find an exhaust parts wholesaler, you can buy things much cheaper
https://www.sau.com.au/forums/topic/411473-exhuast/#findComment-6591704
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
