hi guys, im pretty much new to the whole skyline scene!
after looking around on the web i cant seem to find too much on what would be really ideal to go aftermarket on, so im hoping someone can shed some light
for a car planned to be used as 80% daily and 20% track whats to go for?
bigger sways
rods
links
i have installed BC BR coilovers but thats about it
any help is appreciated
p.s im also looking into upgrading to a r34 gtr braking system very soon, from what i heard this would be the best option for my scenario
thanks
https://www.sau.com.au/forums/topic/411996-daily-suspensionsteering-setup/
24mm adjustable anti-roll bars. HD links are not a bad idea for these.
At least adjustable polyurethane bushes on the front uppers. Adjustable length arms if you want to go harder/nastier with more adjustability (and slightly more chance of getting defected). Same at the rear.
I recommend adjustable length pillow-ball jointed caster arms at the front. Much better than any bushed solution.
New rear subframe bushes. This is hard work, but worth it. If not, then at least some pineapple rings to lock the subframe up a bit.
New diff bushes can be good. This is less about handling than about removing driveline slop and vibration.
Maybe 1° neg camber at rear. Slight toe in for stability or zero toe for a more active rear end.
<2° neg camber at front. 1.5° is usually good. As much caster as you can wind in. Slight negative to zero toe in.
If it gets the wanders in a straight line or tramlines a lot, try a little more front toe in. If it is a bit scary with power on in the corners, try a little more toe in at the rear.
There are a dozen ways to tweak the above settings to suit different tastes and styles. But the above will work without chewing too many tyres. At the track, if you have the adjustability, you can add more neg camber front and rear for the day then take it back off.
GTSBoy is on the money, mine is only a weekender buts gets driven hard.
BC BR coilovers
Whiteline adjustable swaybars, 24mm F, 22mm R
GKTech Pillowball caster arms
Superpro rear camber bushes
1.7 degrees camber front, 1.2 rear, 8 degrees castor
and thats all ive got so far. in my mind its a good place to start if you are short on funds. this is by no means how i will leave my setup. ie i will do pinapples etc when im not so lazy
This has cost $2100ish and im definantly happier with how it rides/handles through the hills. if you plan to do more track days then look at proper adjustable arms.
And of course the best tyres you can afford
on the brakes front the calipers are pretty decent, rda slotted rotors, better pads and braided lines will give a good improvement.
thanks for your share guys, ill definately start looking more in to all these options, i just needed a few ideas first!
and Ahbee just over $2000 sounds like a very resonable price for your setup, have you done all the installments yourself? if so how did you go about it
yea all installs myself, hardest was by far the bushes. $100 press from supercheap auto was all i needed but if i had to do it again i might look at paying someone. coilovers are straightforward, theres plenty of tutorials to follow if your lost, same with swaybars.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
