R33 complete Titanium 4" exhaust with mid muffler and rear mufflers. sounds awesome, just over 6kg
$1500ono
0411742212
Josh
located ne suburbs of adelaide, can post
replaces where the cat goes, if you want to run the cat i can have it shortened to stock cat position, should suit r32/34 with some hanger mods
https://www.sau.com.au/forums/topic/412179-r33-4-titanium-exhuast/
